Cisco 3640 with GPRS modem problem
We are facing a problem while connecting Siemens MC35 GPRS modem to Cisco3640 router through Serial A/S interface the problem is that the chat-script can not start with the modem
Here is the output error followed by the configurations:
‘NOTE The same configurations & the same router working with another modem’
Dial on demand events debugging is on
Router#
Router#
Router#ping 100.100.100.10
Sending 5, 100-byte ICMP Echos to 100.100.100.10, timeout is 2 seconds:
*Mar 1 00:58:52.083: Se2/0 DDR: rotor dialout [best] least recent failure is also most recent failure
*Mar 1 00:58:52.083: Se2/0 DDR: rotor dialout [best] also has most recent failure
*Mar 1 00:58:52.083: Se2/0 DDR: Dialing cause ip (s=10.7.15.129, d=10.7.15.210)
*Mar 1 00:58:52.083: Se2/0 DDR: Attempting to dial *99***1#
*Mar 1 00:58:52.083: CHAT65: Attempting async line dialer script
*Mar 1 00:58:52.083: CHAT65: Dialing using Modem script: tmobile & System script: none
*Mar 1 00:58:52.083: CHAT65: process started
*Mar 1 00:58:52.139: CHAT65: Asserting DTR
*Mar 1 00:58:52.139: CHAT65: Chat script tmobile started...
*Mar 1 00:58:57.187: CHAT65: Chat script tmobile finished, status = Connection timed out; remote host not responding
*Mar 1 00:58:57.187: Se2/0 DDR: disconnecting call
*Mar 1 00:58:58.083: Di1: No free dialer - starting fast idle timer.
*Mar 1 00:59:00.083: Di1: No free dialer - starting fast idle timer.
Success rate is 0 percent (0/5)
chat-script tmobile "" "AT" TIMEOUT 5 OK "AT+CBST=12,0,1" TIMEOUT 5 OK AT+CGDCONT=,,"mobinilbank005" TIMEOUT 5 OK "ATD*99***1#" TIMEOUT 20 CONNECT
interface Tunnel13
ip address 172.16.104.2 255.255.255.252
tunnel source 10.7.15.129
tunnel destination 10.7.15.210
interface Serial2/0
physical-layer async
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
async default routing
async mode dedicated
no peer default ip address
no fair-queue
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string "*99***1#"
dialer-group 1
no cdp enable
no ppp lcp fast-start
line 65
exec-timeout 0 0
no flush-at-activation
script dialer tmobile
modem InOut
modem autoconfigure type default
no exec
transport input all
stopbits 1
1 REPLY
Silver
Re: Cisco 3640 with GPRS modem problem
The issue may be due to following reasons
1. Telco line is not working fine (seems to be one)
2. Bad cable
3. Interface Card is bad
164
