08-23-2006 01:52 AM
Hello
I have a problem with ISDN Dial-in to 3660 Cisco router. I have configured a PRI int for ISDN and i have defined one dialer profile. I have almost 35 remote sites calling to router (computers with ISDN cards). The problem that i can't have two remote points connected at the same time. Is it something wrong with my router configuration?
Configuration example:
version 12.1
isdn switch-type primary-net5
call rsvp-sync
controller E1 3/0
pri-group timeslots 1-31
interface Loopback0
ip address 10.215.255.1 255.255.255.255
interface Loopback1
ip address 10.215.255.2 255.255.255.255
interface FastEthernet0/0
ip address 10.215.0.1 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial3/0:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn fast-rollover-delay 5
isdn incoming-voice modem
no fair-queue
no cdp enable
interface Group-Async0
ip unnumbered Loopback0
encapsulation ppp
async mode dedicated
peer default ip address pool ANALOG
no fair-queue
ppp lcp delay 60
ppp authentication chap pap
ppp ipcp dns 10.215.0.8
group-range 65 80
interface Dialer1
ip unnumbered Loopback1
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
peer default ip address pool ISDN
no fair-queue
no cdp enable
ppp authentication chap pap callin
ppp multilink
ip local pool ANALOG 10.215.90.1 10.215.90.200
ip local pool ISDN 10.215.80.1 10.215.80.100
ip classless
ip route 10.215.80.0 255.255.255.0 Dialer1
ip route 10.215.90.0 255.255.255.0 Dialer1
no ip http server
dialer-list 1 protocol ip permit
no cdp run
dial-peer cor custom
end
08-23-2006 04:29 AM
try and add the lines marked with an arrow --> to your confgiuration, and check if that makes a difference...
version 12.1
call rsvp-sync
controller E1 3/0
interface Loopback0
interface Loopback1
duplex auto
speed auto
no cdp enable
no ip address
encapsulation ppp
--> dialer rotary-group 1
--> ppp authentication chap
no fair-queue
no cdp enable
encapsulation ppp
no fair-queue
ppp lcp delay 60
group-range 65 80
interface Dialer1
encapsulation ppp
no ip mroute-cache
dialer pool 1
--> dialer in-band
dialer-group 1
no fair-queue
no cdp enable
ppp multilink
ip classless
no ip http server
no cdp run
GNT
08-23-2006 09:36 PM
Hello
Ive tried to add two lines to the Serial 3/0:15 interface - the problem is that there is no command like 'dialer rotary-group' in my Cisco IOS.
