Cisco 800 series NAT - Port Fordwarding trouble
Dear,
I am having some problems with my cisco 800 series  router when i try to make  a Port Fordwarding.
I wonder if there are any special access list to  be programmed to enforce this.
Thank you very much for your attention.
Hall of Fame Super Gold
Re: Cisco 800 series NAT - Port Fordwarding trouble
You need to specify what command exactly you entered.
I'm traying with:
access-list 1 permit 10.0.0.0 (My IP Range)
ip nat inside source static tcp 10.0.0.100 3200 interface Dialer1 3200
That is fine, make sure you have ip nat ouside under Dialer1, and Ip NAT inside under internal If.ce
Sorry,
I have IP nat inside but on my vlan interface to connect my ISP, what do yo mean with internal lf.ce?
Ip nat inside on inside interface, outside on the outside.
Kind of logic if you think about.
1862
