Community Member
CISCO 837 ADSL Configuration
Please check the configs below for ADSL connectivity for CISCO 837, I am trying for several days but unable to get through it.
Router#show running-config
Building configuration...
Current configuration : 1957 bytes
version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip name-server 213.42.20.20
ip name-server 195.229.241.222
ip audit notify log
ip audit po max-events 100
ip ssh break-string
vpdn enable
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
no crypto isakmp enable
interface Ethernet0
ip address x.x.x.x x.x.x.x
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
pppoe enable group global
pppoe-client dial-pool-number 1
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/50
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxx
ppp chap password 0 xxxxxx
ppp pap sent-username xxxxxx password 0 xxxxxx
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
password cisco1
login
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
password cisco1
login
transport input all
scheduler max-task-time 5000
end
Router#
Router#
Hall of Fame Super Gold
Re: CISCO 837 ADSL Configuration
Does the circuit sync in first place? Check "show dsl interface".
Community Member
Yes, it does.
Community Member
hi,
please look in to the dialer config,
interface Dialer1
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication pap callin
ppp pap sent-username XXXxx password xxxxxx
dont enable chap use only Pap as mentioned above
Community Member
doesn't work.
You show not give one-line answers and bring more info instead.
To begin with, send revised config, show dsl interface, debug ppp negotiation.
Community Member
Try adding the following
vpdn-group global
request-dialin
protocol pppoe
... and be aware of your MTU settings, I am not sure of your ISP but usually is as follows.
interface Dialer0
mtu 1492
and the physical eth will be...
interface Ethernet0
ip tcp adjust-mss 1452
1108
