Cisco 837 ASYNC dialing problem
Hi all,
Cisco 837 dials through a modem but after some negotiations the session is disconnected automatically.....i've done a lot of troubleshooting but can't resolve the issue...kindly help
Following is the ASYNC int config
chat-script isp "" "AT&H1" TIMEOUT 10 OK "ATDT13131313" TIMEOUT 40 CONNECT
interface Async1
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 5000
dialer string 1111111
dialer-group 1
async default routing
async mode interactive
ppp authentication pap callin
ppp pap sent-username xxx password xxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Async1
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
line con 0
exec-timeout 120 0
modem autoconfigure discovery
modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
script dialer isp
modem InOut
speed 38400
debugging section
Router#ping 1.1.1.1
00:47:27: As1 DDR: place call
00:47:27: As1 DDR: Dialing cause ip (s=10.10.10.1, d=1.1.1.1)
00:47:27: As1 DDR: Attempting to dial isp
00:47:27: CHAT1: Attempting async line dialer script
00:47:27: CHAT1: Dialing using Modem script: isp & System script: none
00:47:27: CHAT1: process started
00:47:27: CHAT1: Asserting DTR
00:47:27: CHAT1: Chat script isp started...
Success rate is 0 percent (0/5)
Router#
00:48:03: CHAT1: Chat script isp finished, status = Success
00:48:05: %LINK-3-UPDOWN: Interface Async1, changed state to up
00:48:05: As1 DDR: Dialer statechange to up
00:48:05: As1 DDR: Dialer call has been placed
00:48:05: As1 PPP: Using dialer call direction
00:48:05: As1 PPP: Treating connection as a callout
00:48:05: As1 PPP: Phase is ESTABLISHING, Active Open
00:48:05: As1 PPP: No remote authentication for call-out
00:48:21: As1 LCP: TIMEout: State REQsent
00:48:21: As1 LCP: O CONFREQ [REQsent] id 99 len 20
00:48:21: As1 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:48:21: As1 LCP: MagicNumber 0x12AC3899 (0x050612AC3899)
00:48:21: As1 LCP: PFC (0x0702)
00:48:21: As1 LCP: ACFC (0x0802)
00:48:23: As1 LCP: TIMEout: State REQsent
00:48:23: As1 LCP: O CONFREQ [REQsent] id 100 len 20
00:48:23: As1 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:48:23: As1 LCP: MagicNumber 0x12AC3899 (0x050612AC3899)
00:48:23: As1 LCP: PFC (0x0702)
00:48:23: As1 LCP: ACFC (0x0802)
00:48:25: As1 LCP: TIMEout: State REQsent
00:48:25: As1 LCP: State is Listen
00:48:27: %LINK-5-CHANGED: Interface Async1, changed state to reset
00:48:27: As1 PPP: Sending Acct Event[Down] id[E]
00:48:27: As1 LCP: State is Closed
00:48:27: As1 PPP: Phase is DOWN
00:48:32: %LINK-3-UPDOWN: Interface Async1, changed state to down
Re: Cisco 837 ASYNC dialing problem
Can you post the output debug ppp authentication?
--Sundar
Sundar,
Actually the problem has resolved by itsself.., if the problem reoccurs, i would show you the debg ppp authentication.....
Akhtar
240
