Cisco 837 not connecting to BT ADSL
Hi.
I am new to the Cisco 837, and trying to set it up to connect with BT ADSL.
Has anyone tried this before? What do I need to do to get it working? I tried everything I can so far, but no luck :-(
David.
Silver
Re: Cisco 837 not connecting to BT ADSL
Hello David,
You can try the following configuration to get you started:
interface Ethernet0
ip nat inside
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode etsi
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname myUsername@btbroadband.com
ppp chap password myPassword
ppp pap sent-username myUsername@btbroadband.com password myPassword
ppp ipcp dns request
ppp ipcp wins request
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 102 interface Dialer1 overload
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
See BT Broadband Support website
http://btbroadband.custhelp.com/cgi-bin/btbroadband.cfg/php/enduser/cci/btb_adp.php?p_sid=4n77yBai&p_faqid=644
--Leon
* Please rate posts.
Hi Leon.
Thanks, as I am new to this router, how do i enter the values?
Through SDM, CWRS or console?
David.
Silver
Hello David,
You can by using the console. Paste your configuration after the "Router(config)#" prompt.
Router>enable
Router#configure terminal
Router(config)#
Alternatevely you can setup your router throug SDM, using the information provided by BT and the accompanied document in my previous post.
Good luck!
--Leon
Hi.
I have already been trying via sdm, but i always get the same results "page not found".
I have just tried your config file with some adjustments for my details, but I saw that fail for 2 lines:
this line failed with a arrow pointing to the e of etsi
and
this failed with an arrow pointing to the p of password, or in my case the first char of my pwd.
of course I change the line above to my adsl uid and pwds.
David.
Hi.
Do I type that list of settings in somewhere? Or import them?
David.
Silver
Hello David,
The config below will work with BT Broadband.
All you will need to do is ensure that you
change the DNS server addresses and use the correct ppp username and
password.
There is no documentation regarding
assistance with configuration guidelines to PPPoA in the UK.
!This is the running config
!version 12.3
no service pad
hostname gateway
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret
username Cisco privilege 15 secret
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip domain name
ip name-server 192.168.0.1
ip name-server 212.159.13.49
ip dhcp excluded-address 192.168.0.1
ip dhcp pool sdm-pool1
import all
network 192.168.0.0 255.255.255.0
dns-server 212.159.6.9 212.159.13.49
default-router 192.168.0.1
no ip bootp server
ip audit notify log
ip audit po max-events 100
ip ssh break-string
no ftp-server write-enable
no crypto isakmp enable
interface Ethernet0
description $FW_INSIDE$$ETH-LAN$$INTF-INFO-Ethernet 10/100$
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/38
dsl operating-mode auto
interface Dialer0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname
ppp chap password 0
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
access-list 1 remark INSIDE_IF=Ethernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Best of luck!
--Leon
Thanks for that, however it still does not work.
The CD light is on, but when I try to browse the web it says page cannot be found etc.
Do you know how I can clear the code/settings from memory? The could that I copy into configure terminal etc.
David.
ahhhh, not sure why, but i can no longer access the router via sdm. Cannot find the ip address???
erm.....help
Silver
David,
Do the following:
Connect to the router using console.
Router>enable
Router#erase startup-config
Router#reload
The startup-config has been removed from NVRAM. Now paste the previous posted configuration into the router.
To access the SDM type the IP address used in the configuration. Check to see if your PC has an IP address assigned to it that matches the IP subnet configured on the router.
Good luck!
--Leon
Hi.
I have followed your instructions, erased the startup, load on yoru last config after changing DNS and chap uid and pwd. However this has not worked.
- On the console it now prompts me for as uid and pwd that I dont know, and now cannot access the console.
- when i try to renew and check my ip address, i get a message saying that the router could not find the DNS server.
When I ran your script, I noticed that there were some other usernames and passwords. But also noticed some errors, see as follows:
gateway(config)#ip domain name ^
% Invalid input detected at '^' marker.
pointing to the d of domainname
gateway(config)#ip ssh break-string
pointing to the B of break-string
gateway(config-line)#login local
could not see what this was pointing to?
gateway(config-line)#transport preferred all
pointing to the a of all
I also noticed other usernames and passwords, but not sure if i should have changed those.
Any ideas?
Hi.
Think I just fixed the uid and pwd problem, by using the "confreg 0x2142" idea found on the www. Its got me back in, but not a clue if it messed anything else up, as I dont have a clue ;-)
Really worried why I cannot get this router to work, but DSL-504T made it so easy ;-)
is there a why I can see if certain bits have worked, so can I check if the router actually connected with ADSL? I am wondering where the problem actually is.
David.
Futher to my last I have just foudn that I get the following after running your script:
Windows IP Configuration
An error occurred while renewing interface Local Area Connection 2 : unable to c
ontact your DHCP server. Request has timed out.
No operation can be performed on Local Area Connection 3 while it has its media
disconnected.
Also I can no long connect to the unti via SDM, but then again, I sont know what IP addderss its using now?
David.
Silver
David,
Look at your router is the interface that connects your PC lit?
When connected to the console issue the command "sh ip interface brief", look at the port connected to your PC. Is both the line protocol as the link status "UP"?
Check the status of the DHCP server, as configured. Issue the command "sh ip dhcp server statistics".
When your LAN interface is up once again, and you have an address assigned you can enter SDM via the IP address 192.168.0.1.
--Leon
Hi.
thanks once again.
problem is that when i run your config, I cannot login to the router, so cannot run your suggestions.
Do you know what username and password is required after the config is installed?
David.
Silver
David,
I assumed that you'd replace the enable secret with your password. See line "enable secret " in the configuration.
As passwords cannot contain spaces, the password should be "
In case this fails you can recover the password. See the detailed instructions on Cisco.com.
http://www.cisco.com/warp/public/474/pswdrec_827.shtml
Live will be much easier with SDM ;-)
Good luck!
--Leon
Hi.
Ok, i reload the router, and re-worked the config you sent me, so now have everything in place.
However, the PC cannot aquire an IP address from the router?
David.
I presume the router IP should be 192.168.0.1?
David.
sorry for dropping in, but you might want to try:
dsl operating-mode ansi-dmt
There is an issue with BT and Cisco 837 routers that require the mode to be ansi-dmt...
HTH,
GNT
Silver
David,
Follow the following troubleshooting methodology:
- Is the physical connection in place?
- Is the interface connected to your PC "up", issue "show interfaces brief" on the command line to check the status. If the interface is administratively disabled you can enabled it by entering "conf t", followed by "interface Fa0/N" where N represents the port number. Issue "no shutdown" on the (config-if) prompt.
- Does either NIC or switchport has the LINK led lit?
- Does either NIC or switchport has a blinking ACT led?
- On your PC enter "ipconfig /all". Does it have an IP address assigned in the range 192.168.0.0/24?
- Ping the router from the PC, is it reachable?
- Open webbrowser to start SDM.
Evaluate if you need the configuration hint mentioned in the previous post.
Good luck!
--Leon
Good idea, as the issue now has changed of course.
Here are my issues now
- Cannot connect to router via iexplorer. Cannot connect with or to SDM.
- PC could not view web pages via the router after being configured.
Answers to your questions:
- Yes. The ADSL is up and tested via another (dlink) router.
- Status says "up" for Ethernet0 and FastEthernet1 (my cable is in that port), but no ip is assigned
- both PC and router have the link light lit
- cannot see any lights blinking for this, but will describe lights last
- No. "Autoconfiguration IP Address. . . : 169.254.46.240", and "Subnet Mask . . . . . . . . . . . : 255.255.0.0"
- No.
- Does not work either via web or via SDM App.
Lights seen:
Router
Ok, steady green
ADSL CD, steady green. When ADSL not plugged in, this goes out and ADSL RXD/TXD flash like crazy.
ADSL RXD, off
ADSL TXD, off
1, Steady On
2, Off
3, Off
4, Off
RXD, Off, Sometimes flashes or flickers
TXD, Off, Sometimes flashes or flickers
NIC
Steady green and another that flashes with traffic.
Hope that helps.
Further details, these are the settings that BT ADSL are requesting:
DNS = auto
VPI = 0 (zero)
VCI = 38
Authentication = CHAP
Modulation = G.DMT
Encapsulation = VC MUX
Encapsulation Protocol = PPPoA, whether USB modem or Ethernet router
Hi.
Ok, so now lets start again, as I have got things back to normal - PHEW!
So now I how the correct IP address, and I can access SDM.
BUT - My original and old problem.
When I try to view a webpage, I get "page not found" etc.
By doing "sh int atm0", I think can see that the ADSL appears to have a connection. I also also done "ping atm interface...", and that is also successful.
Any ideas from here?
David.
YESSSS
Finally got it working, the final problem turned out to be a simple DNS error. So sourced different DNS servers.
Thanks very much for your help and patience!
David.
Silver
Thanks for the complete picture.
It's obvious you can't connect to SDM because of the IP address mismatch.
The Autoconfiguration IP Address (APIPA) address is assigned when a DHCP request times out.
Please issue "debug ip dhcp server" at the console of the router. This will display the IP configuration negotiation between your PC and router.
Router# debug ip dhcp server events
Router# debug ip dhcp server packets
DHCPD:DHCPDISCOVER received from client 0b07.1134.a029 through relay 10.1.0.253.
DHCPD:assigned IP address 10.1.0.3 to client 0b07.1134.a029.
DHCPD:Sending DHCPOFFER to client 0b07.1134.a029 (10.1.0.3).
DHCPD:unicasting BOOTREPLY for client 0b07.1134.a029 to relay 10.1.0.253.
DHCPD:DHCPREQUEST received from client 0b07.1134.a029.
DHCPD:Sending DHCPACK to client 0b07.1134.a029 (10.1.0.3).
DHCPD:checking for expired leases.
Also use "show ip dhcp server statistics" to see if the router receives DHCPDISCOVER broadcasts from your PC.
Good luck!
--Leon
Hi Leon.
Thanks for your help with all this, however please see my last entry as its all now working fine.
I ended up resetting the router, and manually typing in some config. This then enabled SDM to work, and was then back to my original problem.
My original problem was then fixed by supplying the correct DNS server addresses.
Thanks for your help once again, and sorry that this one was so hard work. I know I am new to all this, but really appreciate you time and effort.
THANKS! :-)
David.
667
