cisco 867 router dsl vpn connection to cisco 3030
broow
we have a remote office that has dsl in their office.  we purchased a new Cisco 867 router with an ADSL connection to setup a vpn tunnel to our cisco 3030.  Dose anyone have a working configuration for this setup?
The 867 is a the lasted ver of 15.1.  Not sure what type of dsl connection we have.  Is this important to know?
paolo bevilacqua
Are you being supported by any professional or certified partner ? That would be the best way to obtain sure results for you networking needs.
I think I am close to getting this working.  I can ping from the 867 web addresses both by name and ip address.  I just can not access the web from a work station connected to the 867.  I attached the config file.
thanks
broow
have access to the internet now.
time to try and setup vpn tunnel to 3030
working for 35 weeks now.  Key is to use Cisoc CP express to setup unit
and know your dsl login and passwords
