Cisco 871 / PPPOE / NAT problem
Hi, I'm trying to configure my router 871 with pppoe dialer on FE4 and a private lan on the FE0-3 port.
The dialer0 it's up and works fine. When, from my console router, I ping a public ip, I receive a response.
When I ping from my pc (in the LAN), I can see the VLAN1 ip address (10.10.10.1) and the public ip assigned to the Dialer0 from the provider.
outside the public ip received from the provider, I can't ping anything....
Anyone can help me to resolve this problem ?
Here my configuration
no service pad
service password-encryption
hostname <REMOVED>
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
enable secret 5 <REMOVED>
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name <REMOVED>
ip name-server 212.90.199.2
ip name-server 212.90.192.190
username <REMOVED> privilege 15 secret 5 <REMOVED>
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname <REMOVED>
ppp chap password 7 <REMOVED>
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
End
2 ACCEPTED SOLUTIONS
Silver
Re: Cisco 871 / PPPOE / NAT problem
You need to tell the router what traffic to NAT and what address to translate it to.
i.e. You should translate inside addresses to the dialer 0 address.
As a start - try adding this...
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
ip nat inside source list 101 interface Dialer0 overload
Cheers,
Tim
I see that you have enable IP NAT Inside and IP NAT Outside on the inside and outside interfaces but your configuration is missing the below commands.
access-list 1 permit 10.10.10.0 0.0.0.255
ip nat inside source list 1 interface dialer 0 overload
Arul
*Pls rate if it helps*
Silver
Cheers,
Tim
thank you to every body, problem solved !
Arul
650
