12-03-2005 12:15 PM
Hi I have been struggling with a configuration problem for some time, and I am sure that I missing something simple, but at the moment is it beyond me. The issue is this. I have been given a Cisco 877W ADSL wireless router to use at home. I have the ADSL stuff working and I have the wireless half working. The position of the router is that it is sitting between the internet and a linux firewall/webserver, a l2 managed switch (Intel 460) 24 port switch which has 2 vlans on it one the default and the other running dot1q back to F2 on the router. What I am attempting to do is have my sons friends connect via the wireless interface and have the data travel back through the vlan to the firewall where I am running smnp and traffic shapping. From the inside of the network I can ping everything this includes the wireless attached laptops. my problem is that using the laptop connected to the wireless interface I can ping it'self, the dhcp gateway and the IP of the dialer0 interface I am not able to ping anything else. dot1q is enabled and the vlan is linked back to the dotradio 0.2 sub interface. I am currently using trunking on the router although I have also tried to bridging the interface as well. I can ping directly from the router through to hte switch and I have also unplugged the cable upon which vlan2 travels. This action causes ping to fail so I beleive that the vlan is ok, howerver I have not had any success at all up to this point. Can anyone out there help me please ?
Thank you
Athol Reid
12-11-2005 08:03 AM
Hello Athol,
have a look at this configuration (changed somewhat from the previous), basically what I did was bridge the wireless DOT interface to a BVI, and also add the command ´switchport mode trunk´ to the FastEthernet interface on the router where your switch is connected to.
You might want to make a backup first of the current configuration before putting this one in...)
version 12.4
no service pad
service password-encryption
hostname ADSLW-ROUTER
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
no aaa new-model
--> bridge irb
resource policy
clock timezone PCTime 12
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.49
ip dhcp excluded-address 10.10.10.100 10.10.10.254
ip dhcp pool wireless-1
import all
network 10.10.10.0 255.255.255.0
domain-name reid.co.nz
dns-server 203.109.252.42 203.109.252.42
default-router 10.10.10.1
no ip bootp server
no ip domain lookup
ip domain name reid.co.nz
ip name-server 203.109.252.43
ip name-server 203.109.252.42
ip ssh time-out 60
ip ssh authentication-retries 2
ip ddns update method sdm_ddns1
DDNS both
no spanning-tree vlan 1
no spanning-tree vlan 2
--> This is the interface where your switch is connected to
-->interface FastEthernet3
--> switchport mode trunk
-->no ip address
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
pvc 0/100
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet2
interface Dot11Radio0
no ip address
ssid ADSLW-1
vlan 2
authentication open
guest-mode
-->interface Dot11Radio0.2
-->encapsulation dot1Q 2
-->bridge-group 2
-->bridge-group 2 subscriber-loop-control
-->bridge-group 2 spanning-disabled
-->bridge-group 2 block-unknown-source
-->no bridge-group 2 source-learning
-->no bridge-group 2 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_OUTSIDE$
ip address 192.168.100.254 255.255.255.0
ip verify unicast reverse-path
ip nat inside
ip virtual-reassembly
interface Vlan2
description $FW_INSIDE$
ip address 172.16.11.14 255.255.255.0
ip nat inside
fair-queue 2 256 0
interface Dialer0
ip ddns update sdm_ddns1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname USERID
ppp chap password 7 PASSWORD
ppp pap sent-username USERID password
interface BVI2
-->ip address 10.10.10.1 255.255.255.0
-->ip policy route-map dotradio0.2
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 remark From Vlan1 to outside
access-list 2 permit any
dialer-list 1 protocol ip permit
snmp-server community public RO
no cdp run
route-map dotradio0.2 permit 10
match ip address 1
set ip next-hop 172.16.100.4
-->bridge 2 route ip
control-plane
end
Let me know if this somehow works better...
GP
12-11-2005 12:56 PM
Hi Georg
Thanks for the Conf I include the new one below:
version 12.4
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
no ip source-route
ip cef
import all
no ip bootp server
no ip domain lookup
ip ssh time-out 60
DDNS both
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/100
interface FastEthernet0
interface FastEthernet1
no ip address
ssid ADSLW-1
vlan 2
authentication open
guest-mode
world-mode dot11d country NZ both
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2462
station-role root
no snmp trap link-status
no cdp enable
bridge-group 2
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
fair-queue 2 256 0
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
interface BVI2
ip nat inside
ip classless
ip http server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 192.168.100.252 222 interface Dialer0 222
ip nat inside source static tcp 192.168.100.252 4899 interface Dialer0 4899
ip nat inside source static tcp 192.168.100.252 443 interface Dialer0 443
access-list 1 remark From Wireless to dialer 0
access-list 1 remark SDM_ACL Category=18
access-list 101 remark From vlan 1 to outside
access-list 101 remark SDM_ACL Category=2
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
no cdp run
match ip address 1
control-plane
bridge 2 route ip
OK what happened was that once the conf was in there was no comms between 10.10.10.1 and anything and no translation on the dialer 0. Once this was done I am back to where I was prior to any changes. can't think of anything else at this point
Kind Regards
Athol Reid
12-11-2005 01:14 PM
Hello Athol,
not good...
I´ll check again, and let you know.
GP
12-11-2005 02:05 PM
Hello Athol,
did you actually have the ´switchport mode trunk´ command configured on your FastEthernet 2 interface already, that is, before I sent you the last configuration ? I am thinking that you might need to add ´switchport trunk encapsulation dot1q´, since you are connecting to a non-Cisco switch, and since the default trunking mode on Cisco is ISL (which is Cisco-proprietary)...
GP
12-11-2005 07:34 PM
Hi Georg
Yes you are right, I shall reloasd and advise.
Kind Regards
Athol reid
12-11-2005 10:12 PM
Hi Georg
Ok I removed all trunking commands and started again. Still no joy.
Kind Regards
Athol Reid
12-11-2005 10:48 PM
Hello Athol,
sorry for the misunderstanding, what I meant to say was: make sure that the trunking is configured:
GP
12-12-2005 11:17 AM
Hi Georg
Sorry it was the way I worded my reply to you. Your instructions were fine. I removed then reinserted the commands to make sure I started at the beginning again. I note that the command is "switchport trunk encapsulation dot1" rather than "dot1q" can you confirm this is correct please? In the mean time I shall input the commands given. I have now done this and when I run "sh run int fast 2" command all I get back is :
There is not indication that encapsulation has been accepted do you know if this is correct ?
At the moment I can ping the 10.10.10.0 network, Translation is working on the dialer 0 interface and I can ping the 192.168.100.254 interface.
I am wondering is there any way to tell if encapsulation is actually working ?
for info only: I have been given a cisco catalyst 500 express switch to use for fault finding. but I do not want to introduce any new problems at this point so I shall not be using this unless you indicate that it will be ok.
Kind Regards
Athol Reid
12-12-2005 12:38 PM
Hello Athol,
ok...
Can you put the configuration back to what it was when you had connectivity except for the VLAN 2 clients, then add one of the VLAN 2 clients directly to one of the FastEthernet ports on your router (and put that port in VLAN 2 with the ´switchport access vlan 2´ command) ? Does that client then have connectivity ?
GP
12-12-2005 08:07 PM
Hi Georg
I changed the config back and after testing connectivity I then got my wifes pc (I'm in trouble) changed the IP address to 172.16.11.25 and put it directly off FastEthernet 3 put in the command under interface FastEthernet 3 "switchport access vlan 2"
I am sorry to report that it has not worked. I have included the relevant parts of the conf below
no ip address
ssid ADSLW-1
vlan 2
authentication open
guest-mode
channel 2462
station-role root
ip nat inside
no cdp enable
bridge-group 2
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
fair-queue 2 256 0
bridge-group 2
Kind Regards
Athol Reid
12-13-2005 01:01 AM
Hello Athol,
can you try and take the bridge-group commands off interface Vlan 2 ?
interface Vlan2
ip nat inside
fair-queue 2 256 0
-->no bridge-group 2 spanning-disabled
Basically, what I am trying to do is isolate the problem to one piece of equipment, which in your case I think might be the switch. If we can prove that a PC connected directly to the router on Vlan 2 works, the only piece of equipment that is left is the switch...
GP
12-13-2005 03:46 AM
Hi Georg
I removed all reference to bridging and I put FastEthernet 3 into vlan 2 and connected a workstation direct to FastEthernet 3 port and was able to ping from the 10.10.10.0 network that computer
Kind Regards
Athol
12-14-2005 12:49 PM
Hello Athol,
I have a feeling we are getting stuck...
Can you contact me offline ? If you have Skype, my ID is 'solutionfindershelpdesk', if you have MSN, my ID is helpdesk@solutionfinders.nl'. Otherwise, my email address is helpdesk@soltuionfinders.nl...
GP
