Cisco ACS upgrade
m.feuerer
is it possible to upgrade from ACS v.3.3 directly to 5.2 ? Or do I need version 4.X in between?
Thanks for your help.
Cheers, please kindly mark the post as answered if you have no further question. Thank you.
5 Replies 5
Jennifer Halim
You can't upgrade ACS 3.3 directly to ACS 5.2.
ACS 5.x is completely different to ACS 3.x and 4.x.
There is specific hardware that you need to run ACS version 5.x, and here is the list:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/release/notes/acs_52_rn.html#wp70853
Here is the migration guide to ACS 5.x:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/migration/guide/Migration_Book.html
Hope that helps.
Thanks for your answer.
I think my question was unclear. I know about the different hardware. We plan to install the new 5.2 in VMware.
My question is, if I can import our user datas from version 3.3 to 5.2 directly?.
Thanks.
No, you can't migrate user data directly from 3.x to 5.x.
And it's quite a complex process to migrate from 4.x to 5.x, and here is the migration guide specifically:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/migration/guide/Migration_overview_oper.html
It's a 2 phase process and you would need 2 servers for the migration (1 migration server and 1 ACS 5.x server).
OK, I see.
Thanks for your quick help.
