CISCO ACS
Hi All
I am new to the CISCO ACS software ,at present our vpn clients are being authenticated using the cisco acs
My problem is when they get connected they are being assigned with a subnet mask and gateway can any one help me to find out where it is configured and how can it be changed .
NOTE :- there is no radius attribute IETF configured on the acs
Re: CISCO ACS
VPN users do not necessarily receive their ip address and mask etc via radius. This may very well be performed by an ip pool on the vpn device. In that case, only the authentication would be done via ACS.
What device are you using?
Can you post the config?
regards,
Leo
Re: CISCO ACS
hi leo
tks a lot for your reply ,
ok also how is the gateway ip is decided for the client
please reply
Re: CISCO ACS
What is ure VPN termination device? ASA, VPNC, IOS Router?
Farrukh
Re: CISCO ACS
hi sir
it is cisco ios router
Re: CISCO ACS
hi I am sorry for the wrong info
it is terminating on Pix 515
Re: CISCO ACS
Can you post the output of
show run vpn-addr-assign
If your Firewall is running 7.x
Farrukh
213
