10-17-2014 01:59 PM
I just updated my MacBook Pro (Retina, 15-inch, Early 2013) to latest OS X Yosemite (10.10 (14A389)). Cisco AnyConnect Secure Mobility Client
is generating an error while trying to connect:
Posture Assessment Failed: CSD library signature verification failed.
Cisco AnyConnect Secure Mobility Client VPN User Messages, Release 3.1 - Cisco states following:
Description The signature of the library could not be verified. This indicates a problem with the CSD library.
Recommended Action Remove the library from the cache, and try a new connection.
I tried recommended action yet it did not help me solve my issue, as I'm still unable to connect to VPN.
10-17-2014 03:00 PM
Do you have AnyConnect 3.1.05187? That's the first version to support OS X 10.10.
10-21-2014 09:20 AM
I'm using latest version that is available for download through Cisco's site which is 3.1.05187, and still unable to connect!
11-05-2014 12:57 PM
We're seeing the same error with that client, were you able to find a fix? thanks.
11-05-2014 01:36 PM
We removed CSD from the configuration and used the latest version of HostScan instead:
no csd image disk0:/csd_3.5.841-k9.pkg
csd hostscan image disk0: /anyconnect-win-3.1.05187-k9.pkg
hostscan has to be on version 3.1, same as client in order for this to work! as soon as we updated our hostscan to 3.1+, i was able to vpn in without any issues)
