Community Member
Clear Line does not clear a reverse telnet connection
I have a 2511 that I use in my lab as a terminal server. Connections work great, except using the command "clear line x" does not always clear the connections. I enter the command "clear line 1" and press enter. I get the [confirm] message. I press enter. Doing a show line still shows the line as being tied up (indicated by an asterisk). I can repeat the clear line command several times with no changes. Its not all the lines, only some of them. (I have 2xoctal cables being used with 16 devices). Thoughts?
Jeff
1 REPLY
Re: Clear Line does not clear a reverse telnet connection
Hi there!
After you clear one line (I'm talking about the lines that you observe that you have problems) and you try to do a reverse telnet on that line, it is working?
Cheers,
Calin
175
