Webcast-Catalyst9k
Configure Point to Point with two WIC-1AM= Cards
I recently purchased two WIC-1AM cards that I would like to use over analog POTS to serve as a backup for communications between two Cisco 2621XM routers when the primary Connection goes down. I would like the central router to dial out to the remote sites. I tried to configure this as best I could, but am currently unsuccessful. Any aid you can provide in either auditing my current config and/or implementing this would be greatly appreciated.
Re: Configure Point to Point with two WIC-1AM= Cards
Here are the Configs:
Central Site Config:
version 12.2
service config
service timestamps debug uptime
service timestamps log uptime
hostname Central
enable secret xxx
enable password xxx
ip subnet-zero
chat-script sillyman "" "atdt 8281452" TIMEOUT 60 "CONNECT"
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip access-group DOWSCADA1921 in
speed auto
half-duplex
interface Serial0/0
ip address 10.1.100.1 255.255.0.0
encapsulation frame-relay
no fair-queue
interface FastEthernet0/1
no ip address
ip access-group WANFROMDOW in
ip access-group WANFROMWAN out
duplex auto
speed auto
traffic-shape rate 56000 7952 7952 1000
interface Async2
ip address 11.x.x.1 255.255.0.0
encapsulation ppp
dialer in-band
dialer string 8281452
dialer-group 1
async mode dedicated
ip default-gateway 192.168.0.0
ip classless
ip default-network 192.168.0.0
ip route 10.1.176.0 255.255.255.0 10.1.176.1
ip route 11.x.x.0 255.255.0.0 11.1.159.1
ip route 192.168.1.0 255.255.255.0 192.168.1.1
ip route 192.168.1.0 255.255.255.0 192.168.0.2
ip route 192.168.116.0 255.255.255.0 10.1.116.1
ip route 192.168.119.0 255.255.255.0 10.1.119.1
ip route 192.168.128.0 255.255.255.0 10.1.128.1
ip route 192.168.150.0 255.255.255.0 10.1.150.1
ip route 192.168.157.0 255.255.255.0 10.1.157.1
ip route 192.168.159.0 255.255.255.0 10.1.159.1
ip route 192.168.159.0 255.255.255.0 Async2 180
ip route 192.168.165.0 255.255.255.0 10.1.165.1
ip route 192.168.176.0 255.255.255.0 10.1.176.1
ip http server
ip pim bidir-enable
ip access-list extended DOWSCADA1921
permit tcp host 192.168.0.10 any eq telnet
deny tcp any any eq telnet
permit ip any any
ip access-list extended WANFROMDOW
permit ip 192.168.0.0 0.0.255.255 any
permit ip 10.1.0.0 0.0.255.255 any
ip access-list extended WANFROMWAN
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
dialer-list 10 protocol ip permit
snmp-server community public RO
line con 0
speed 19200
line 2
modem InOut
transport input all
transport output pad v120 telnet rlogin udptn
stopbits 1
speed 115200
flowcontrol hardware
line 33 40
line aux 0
line vty 0 4
password xxx
login
end
Central#
Remote Site Config:
version 12.2
hostname Remote
enable secret xxx
enable password xxx
ip subnet-zero
chat-script sillyman "" "atdt 2455909" TIMEOUT 60 "CONNECT"
ip address 192.168.159.1 255.255.255.0
no ip mroute-cache
speed auto
half-duplex
interface Serial0/0
ip address 10.1.159.1 255.255.0.0
no ip mroute-cache
no fair-queue
ip address 172.x.x.1 255.255.0.0
no ip mroute-cache
duplex auto
speed auto
interface Async2
ip address 11.x.x.2 255.255.0.0
encapsulation ppp
dialer in-band
dialer string 2455909
dialer-group 1
async mode interactive
no ip classless
ip route 10.0.0.0 255.0.0.0 10.1.100.1
ip route 10.1.0.0 255.255.0.0 10.1.100.1
ip route 11.1.0.0 255.255.0.0 11.1.100.1
ip route 11.1.0.0 255.255.0.0 Async2
ip route 172.16.0.0 255.255.0.0 172.16.0.1
ip route 192.168.0.0 255.255.0.0 Async2 180
ip route 192.168.0.0 255.255.255.0 10.1.100.1
ip route 192.168.1.0 255.255.255.0 10.1.100.1
ip http server
ip pim bidir-enable
line con 0
line 2
modem InOut
transport input all
stopbits speed 115200
line aux 0
line vty 0 4
password xxx
login
end
Remote#
Change your chat script to the following on both sides.
chat-script sillyman AT OK atdt\T TIMEOUT 60 CONNECT\c
Here is a list of debugs you can run to see what is happening.
debug chat
debug dialer
debug ppp nego
debug ppp auth
354
