Webcast-Catalyst9k
Configuring PPPoE on 2801 with WIC-1ADSl
Hello All!
I try to configure 2801 with WIC-1ADSl
part of my config is:
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/55
encapsulation aal5mux ppp dialer
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password 0 xxx
ppp pap sent-username xxx password 0 xxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
show int dialer
but in this configuration i cann't connect to ISP (and recive ip address)
show int Dialer 1
Dialer1 is up, line protocol is up (spoofing)
Bound to:
Virtual-Access2 is up, line protocol is down
yourname#debug dialer packets
Dial on demand packets debugging is on
yourname#ping 195.161.136.2
Sending 5, 100-byte ICMP Echos to 195.161.136.2, timeout is 2 seconds:
*Mar 15 12:37:33.523: Di1 DDR: ip (s=192.168.0.230, d=195.161.136.2), 100 bytes,
outgoing interesting (ip PERMIT)
*Mar 15 12:37:33.523: Di1 DDR: Cannot place call, no dialer string set.
*Mar 15 12:37:35.523: Di1 DDR: ip (s=192.168.0.230, d=195.161.136.2), 100 bytes,
Can anybody help me to correct problem?
Thank you very much
Bronze
Re: Configuring PPPoE on 2801 with WIC-1ADSl
try and change the ppp authentication to:
ppp authentication pap chap callin
in order for the router to try and authenticate with PAP first.
In addition, you might want to try and add:
dialer-list 1 protocol ip permit
to your configuration.
Also, typically, when connecting to an ISP, you would implement NAT. Do you have public IP addresses assigned to yuor internal network ? If not, try and make the following changes:
interface FastEthernet0/0
ip address x.x.x.x y.y.y.y
ip nat inside
interface ATM0/1/0
no ip address
pvc 0/55
interface Dialer1
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
-->ip nat outside
ip classless
Nethelper
Tnank you very much!!!
the first part of my task is solved...
now my config is
yourname#show run
version 12.4
ip domain name yourdomain.com
vpdn enable
vpdn ip udp ignore checksum
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.0.230 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
interface ATM0/1/0
no ip address
interface ATM0/1/0.1 point-to-point
pvc 0/55
oam-pvc manage
interface Dialer0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 2 protocol ip permit
But I need to configure second chanel with PPPoEoA (ethernet over ATM or encapsulation MAC or Enet encap)encapsulation for access to inside SP network (172.16.x.x etc.)
How I can do this?
Bronze
I am not clear on what you are looking for. Who is your ISP, and what are you trying to accomplish, that is, what do you mean by ´access to inside SP network´?
Nethelper
I need to create 2 channel:
1. PPPoE Authenticated channel to public Internet...
2.UnAuthenticated channel to private SP network
for this network SP use pvi/vci 0/33
and "encapsulation protocol" that It called
"Enet Encap"
this is Zyxel feature, and I don't now what is it in Cisco terminology... but suspect what is PPPoEoA
and I Try to find this solution on Cisco system...
interface ATM0/1/0
no ip address
pvc 0/55
oam-pvc manage
interface ATM0/1/0.2 point-to-point
ip address 192.168.30.100 255.255.255.0
atm route-bridged ip
pvc 0/33
oam-pvc manage
interface Dialer0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
ip classless
ip route 192.168.1.0 255.255.255.0 192.168.30.200
1727
