05-30-2012 06:35 AM
Hi we have two AS5350 in Production which reached LDOS end of last year.
On this AS5350 is implemented a special Service which has to be offered in the future as well where they need digital Modems (details to this Service later on). so customer wants to migrate to a new HW, like to a ISR-G2 2951 with PVDM2-ADPTR , PVDM2-36DM and VWIC3-2MFT-T1/E1 .
So on the running AS5350 we have a config like following.
ip host gpsstream_port4101 4101 172.18.100.11
ip host gpsstream_port4201 4201 172.18.100.11
ip host gpsstream_port4301 4301 172.18.100.11
resource-pool enable
resource-pool group resource RTK
range port 1/0 1/14
resource-pool group resource DGPS
range port 1/15 1/24
resource-pool group resource MGPS
range port 1/25 1/29
resource-pool profile customer RTK
limit base-size all
limit overflow-size 0
resource RTK speech
dnis group RTK
resource-pool profile customer DGPS
limit base-size all
resource DGPS speech
dnis group DGPS
resource-pool profile customer MGPS
limit base-size all
resource MGPS speech
dnis group MGPS
controller E1 3/0
pri-group timeslots 1-31
interface Serial3/0:15
description S2
no ip address
isdn switch-type primary-net5
isdn caller 436641061498
isdn caller 436641509409
isdn incoming-voice modem
no cdp enable
interface Group-Async0
no ip address
group-range 1/00 1/59
dialer dnis group DGPS
number 2
dialer dnis group MGPS
number 3
dialer dnis group RTK
number 1
line 1/00
no motd-banner
no exec-banner
exec-timeout 0 0
no flush-at-activation
logging synchronous
no vacant-message
login authentication nologin
modem InOut
autocommand telnet gpsstream_port4101 /stream
no activation-character
special-character-bits 8
transport input all
escape-character NONE
autoselect during-login
autohangup
line 1/15
no motd-banner
no exec-banner
exec-timeout 0 0
logging synchronous
no vacant-message
modem InOut
autocommand telnet gpsstream_port4201 /stream
transport input all
autohangup
line 1/25
no motd-banner
no exec-banner
exec-timeout 0 0
logging synchronous
no vacant-message
modem InOut
autocommand telnet gpsstream_port4301 /stream
transport input all
autohangup
What we achive with this configuration is that based on the called number (specified in DNIS group) we are connected to a Host with a particular tcp-port (different ressource-pools and different autocommands on the lines)
The configuration of ressource-pools and ressource-pool groups is not supported aon the ISR-G2 (G1 as well)
So the question how to mirgrate our config to an ISR-G2 ?
(ther is a command modem-pool und which you can configure the lines and the called number, maybe this is a way to configure the same, but I do not have equipment to test this)
Thx
Hubert
06-01-2012 09:45 AM
The ISR G2 router do not support all AS features.
You can use the 5400 to replace 5350.
03-18-2013 05:39 AM
Hubert, did you resolve this problem? We require the same for our RTK network and need a suitable replacement for our AS5350XM's.
I should add - we are not using resource-pools but do need the autocommand telnet
