10-11-2006 07:03 AM
Hi all,
could someone help me what is best
solution to connect Central and remote sites together with ISDN T1/E1?
Could someone help me with how to config this and give me any advice?
Thanks a lot.
BR
jl
10-12-2006 06:28 AM
This is a basic dialer config based on using a PRI rate E1 line (europe)for your central site and a BRI rate line for your remote sites (just one dialer example shown)
Central site
username Router_A password xxxx
controller E1 x/x
pri-group timeslots 1-31
Interface serialx/x:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-net5
fair-queue
ppp authentication chap
interface Dialer1
bandwidth 64
ip address 192.168.250.158 255.255.255.252
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name Router_A
dialer idle-timeout 1800
dialer string 9876543210
dialer-group 1
priority-group 1
compress stac
ip route 10.10.10.0 255.255.255.0 192.168.250.157
_____________________________________
Remote Site (router_A)
username Central password xxxx
interface BRI0
no ip address
encapsulation ppp
isdn switch-type basic-net3
Interface Dialer1
ip address 192.168.250.157 255.255.255.252
encapsulation ppp
dialer pool 1
dialer string 0123456789
dialer max-call 1
dialer-group 1
priority-group 1
compress stac
ip route 0.0.0.0 0.0.0.0 192.168.250.158
this is just the basics
hope this helps
Stu
10-19-2006 07:28 AM
Hi Stu,
thanks a lot for help. What does dialer max-call 1 and priority-group 1 mean?
We will coonect both sites with T1/E1 line.
Is over there difference?
Thanks a lot for help.
BR
jl
10-20-2006 04:01 AM
Hi John
the dialer max-call 1 is an optional command which would stop multilink from using more channels (if multilink was configured which it isn't in this example so its not really needed).
The priority-group 1 command attaches a prioritised list (1 in this example)of traffic to the dialer interface ( its a QOS thing).
Below is an example of some prioritised traffic (telnet).
priority-list 1 protocol ip high tcp telnet
priority-list 1 protocol ip normal
If there is congestion in theory telnet should be prioritised before the rest of the ip traffic..
Stu
10-20-2006 04:30 AM
Hi Stu,
thanks a lot for an explanation. Pls. could you explain me how we should or how it changes in T1/E1 a solution on both sides?
Thanks a lot for a help.
BR
jl
10-22-2006 11:06 PM
John
It shouldn't be any different. If you set up each ends controller, its timeslots and configured the d channel for each you can simply create dialer interfaces similar to above.
please rate if helps
regards
Stu
