Webcast-Catalyst9k
connection to home on dsl
Hi all , can anyone tell me the best way to connect to home via my adsl line and cisco router ? I want to connect to my pc, as I only have 1 address on the interface I would need to use port forwarding, but what if I wanted full blown access to my pc ?
1 REPLY
Re: connection to home on dsl
Hey there Carl,
It depends on the kind of access you want.
All you need to do is forward the ports for the services that you're after. The one you might be looking for is 3389 for remote desktop.
Check out this link for well known port numbers:-
http://www.iana.org/assignments/port-numbers
Hope that helps,
LH
Please rate all posts
110
