Converting T1 controller to E1 controller (as5300)
Here i have an as5300 with T1 controller my question is : Is there a way to logicaly or with some configuration change T1 controller to acts like a E1 controller.
also i know that T1 has 24 timeslots and E1 has 30 Timeslots but its not important for me if T1 works like E1.
if it could happen ,please tell me how.
Thanks.
Regards Bahman Mozaffari.
1 REPLY
Purple
Re: Converting T1 controller to E1 controller (as5300)
I don't believe the AS5300 supports any T1/E1 cards - which means that there is no way you can convert a T1 controller to an E1 controller.
I'm afraid you'll have to purchase an E1 module for what you want.
Hope that helps - pls rate the post if it does.
Paresh
Paresh
147
