data call for transfer capability=3.1kHz Audio
cfajardo1_2
i cannot establisg a call from bri to E1. Iam doubting part of the debug which shows
Transfer Capability = 3.1kHz Audio
will the above message (parameter) allow incoming data calls?
paolo bevilacqua
The call is coming as either voice or fax/modem. Whic hardware do you have, and what is calling ?
calling party is BRI and the called party is E1.
we cannot establish the call. But if we do it the other way around (E1 to BRI) it will work.
we have this conf on E1
controller E1 2/0
framing NO-CRC4
pri-group timeslots 1-10,16
interface Serial2/0:15
no ip address
encapsulation ppp
dialer pool-member 5 max-link 2
isdn switch-type primary-net5
isdn incoming-voice modem
ppp authentication chap
ppp multilink
which hardware and IOS are you using ?
