Device Passwords. Using SSH, Console, VTY, and AAA
I know that without using SSH, and strictly using telnet, console, I can set a password for both my VTY lines and the console separately.
When I enable AAA for local SSH username and passwords, it asks me for a username and password even when I only connect using the console, when before enabling AAA, connecting to the console would just ask me for the password, and not a username and password.
Is this normal?
Does enabling AAA username and passwords take precedence over all authentication on all ports?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Device Passwords. Using SSH, Console, VTY, and AAA
Nelson
Yes this is normal. And yes enabling aaa new-model does take precedence over all authentication on all ports.
If you still want to login on the console and just use the console password it is possible to configure the router to do this (though frankly AAA is usually more secure and is preferred). If you want the console to authenticate with the line password the config might look something like this:
aaa authentication login cons_auth line
line con 0
login authentication cons_auth
Rick
Nelson
line con 0
Rick
Thanks so much, Rick. Helps a lot.
Nelson
I am glad that my response was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that there was a response which did lead to a solution.
Rick
272
