Dial-backup in 1841 and 2801
cweissheimer
Please, does anyone know if 1841 and 2801 support dial-backup in AUX port using PPP ?
I am trying not use WIC-1AM.
Cleber
13 Replies 13
desai.jaideep
Level 5
Level 5
Yes its possible.Pls refer to following link.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080093d2b.shtml
Pls rate all helpful posts.
JD
i have a same problem.
i try to use async as a backup for serial.
when the s0 is down, i can see there is one action on async, but not up, it's down. i dont know why...
and when s0 go back to up, async go to standby.
could any tell me, why async cannot go up?
here is my config:
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
interface FastEthernet0/0
ip address 172.16.84.200 255.255.255.0 secondary
ip address 192.168.78.5 255.255.255.240
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0/0
bandwidth 64
backup delay 5 5
backup interface Async1
ip address 9.24.50.98 255.255.255.252
ip nat outside
interface Async1
ip address 9.24.253.29 255.255.255.0
ip nat outside
encapsulation ppp
dialer in-band
dialer idle-timeout 600
dialer string 63295453
dialer-group 1
async mode dedicated
ppp authentication pap callin
ppp pap sent-username j password 0 jjj
routing dynamic
router eigrp 188
network 9.24.50.96 0.0.0.3
network 9.24.253.0 0.0.0.255
network 172.16.84.0 0.0.0.255
distribute-list 2 out Async1
distribute-list 2 out Serial0/0/0
no auto-summary
ip default-gateway 192.168.78.1
ip route 192.168.78.16 255.255.255.240 192.168.78.1
ip route 192.168.78.48 255.255.255.240 192.168.78.1
ip http server
no ip http secure-server
ip nat pool dynamic 172.16.84.1 172.16.84.200 netmask 255.255.255.0
ip nat inside source list 1 pool dynamic overload
ip nat inside source static 192.168.78.21 172.16.84.201
access-list 1 permit 192.168.78.0 0.0.0.255
access-list 2 permit 172.16.84.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
login local
modem InOut
modem autoconfigure discovery
flowcontrol hardware
line vty 0 4
scheduler allocate 20000 1000
end
I think you need a chat script to activate the line. Try and add the following to your config (additions are marked by -->):
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
--> chat-script async ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 45
CONNECT \c
ip cef
ip nat inside
duplex auto
speed auto
bandwidth 64
backup delay 5 5
ip address 9.24.x.x.255.255.252
ip nat outside
interface Async1
ip address 9.24.x.x.255.255.0
ip nat outside
encapsulation ppp
dialer in-band
dialer-group 1
routing dynamic
router eigrp 188
network 9.x.x.96 0.0.0.3
network 9.x.x.0 0.0.0.255
no auto-summary
ip http server
control-plane
line con 0
line aux 0
--> script connection async
login local
modem InOut
line vty 0 4
end
Can you try this and check if it makes a difference ?
GNT
i tried this config on my router, i have to use
'script dialer async' to activate it. it will go on
using default script if 'script connection async'.
now seems the problem is on that script, here is my debug:
ug 3 04:02:17.795: CHAT1: Attempting async line dialer script
*Aug 3 04:02:17.795: CHAT1: Dialing using Modem script: async & System script:
none
*Aug 3 04:02:17.795: CHAT1: process started
*Aug 3 04:02:17.795: CHAT1: Asserting DTR
*Aug 3 04:02:17.795: CHAT1: Chat script async started
*Aug 3 04:02:17.795: CHAT1: Sending string: AT Z
*Aug 3 04:02:17.795: CHAT1: Expecting string: OK
*Aug 3 04:02:22.795: CHAT1: Timeout expecting: OK
*Aug 3 04:02:22.795: CHAT1: Chat script async finished, status = Connection tim
ed out; remote host not responding
I'm using one TPLink TM-EC5658V Modem.
thanx a lot!
You need to configure that in bot of the routers.....
JD
sry, this is the debug with ur config:
*Aug 3 05:36:18.219: As1 DDR: place call
*Aug 3 05:36:18.219: As1 DDR: Dialing cause ip (s=9.24.253.29, d=224.0.0.10)
*Aug 3 05:36:18.219: As1 DDR: Attempting to dial 58845454
*Aug 3 05:36:18.219: CHAT1: Attempting async line dialer script
*Aug 3 05:36:18.219: CHAT1: Dialing using Modem script: async & System script:
none
*Aug 3 05:36:18.219: CHAT1: process started
*Aug 3 05:36:18.219: CHAT1: Asserting DTR
*Aug 3 05:36:18.219: CHAT1: Chat script async started
*Aug 3 05:36:18.219: CHAT1: Sending string: AT
*Aug 3 05:36:18.219: CHAT1: Expecting string: OK
*Aug 3 05:36:23.219: CHAT1: Timeout expecting: OK
*Aug 3 05:36:23.219: CHAT1: Chat script async finished, status = Connection tim
*Aug 3 05:36:23.219: As1 DDR: disconnecting call
HI
You need to configure the routers at both the sides.What is the response on other side?
JD
i only take responsible for one side,
and the other side is ok, i think, they already got connection with other dialers.
In that case, we will require the config. of other side, b'coz we have to make sure that you are using their settings.The debug output seems to be OK with your side, there is some issue with the remote side.
JD
hi,
i got a news really really bad. maybe the problem is on my line, connecting modem and aux!
u know to connect modem i need a RS232-Rj45, and the RS232 head should be male.
there is one line shipped with router, RS232(female)-RJ45, so i bought one male-male commutator for it.
now i guess this commutator is the criminal.
i checked the AT commands by connect the modem to COM2 directly, and they can work.
and i noticed when the modem connect to computer, status light of 'TR' which means DTE ready is on.
but when i connect modem to router, TR is off!
what's very strange is, with this commutator, the router can find the async interface, after i config
aux.
how can i make sure the commutator is ok?
if not, how can i make one line, i mean how is the order of that line?
many thanx
none
Can you try following commands?Your config for serial is OK.
The chat script is there, I do not know what modem you have...I have used an Zyxel modem.
username cisco password 0 cisco
chat-script default ABORT ERROR ABORT BUSY ABORT "NO ANSWER" "" "ATDT\T" TIMEOUT 60 CONNECT \c
modemcap entry zyxel:FD=&F:AA=S0=1:CD=&C1:DTR=&D3:HFL=&H3:SPD=&B1:BER=&K4:NER=&K0:NEC=E0:NRS=Q1
interface Dialer 1
encapsulation ppp
dialer in-band
dialer idle-timeout 120
dialer map snapshot 1 name broadcast
dialer map ip name modem-script default broadcast
dialer-group 1
pulse-time 3
ppp authentication chap
snapshot server 15 dialer
interface Async 1
no ip address
dialer rotary-group 1
line aux 0
autoselect ppp
modem InOut
transport input all
stopbits 1
speed 11500
Pls rate helpful posts.
JD
cweissheimer
One related question: in 837 there is virtual AUX (whhere the CON can work as AUX), but is this case will I lost the console port to do management, for example ?
Cleber
