Dial Backup Solution for Retail Store
tech011
I need to config a dial-in only solution for a 3800 with the following modules:
NM-1CE1T1-PRI
PVDM2-24DM
PPP dial-in works fine and gives out an address with the "ip local pool dialin" and "peer default ip address pool dialin" commands.
If I use SLIP, dynamic IP addressing won't work. That's not the issue though.
We currently have a 3com Total Control box that we are using today; which are being replaced with the 3800 routers.
I was told by the software folks that supply the POS software for our 2500 stores, that the dial backup connection does not use either SLIP or PPP. They state it uses a "serial ASYNC low speed connection to the 3COM box. The total control box, in turn converts to IP prior to sending the message to the server that processes transcations at corporate."
Does Cisco support this scenario? If so, what would the config look like?
You need exec under line. Can set modem to In, but that's a detail.
7 Replies 7
paolo bevilacqua
Yes. Simply configure autommand with telnet to server ip address and port.
You can shorten the connection time with the appropriate AT commands for the modems. This is very important for slow speed POS.
What would that config look like. Here is my currect config that works with PPP no authentication:
interface Group-Async0
ip unnumbered FastEthernet0/0
encapsulation ppp
async mode dedicated
group-range 0/386 0/409
line 0/386 0/409
modem Dialin
transport input all
Autocommand is a line config mode command.
You would remove the interface gr0 altogether.
You can check about commands that you
don't know in the reference manual.
Please remember to rate useful posts with the scrollbox below.
Still does not work. Here is my config. client connects fine, but the autocommand does not execute:
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login noaut none
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa session-id common
clock timezone EDT -5
clock summer-time EDT recurring
network-clock-participate slot 1
network-clock-select 1 T1 1/0
controller T1 1/0
framing ESF
linecode b8zs
cablelength short 110
ds0-group 0 timeslots 1-24 type e&m-fgb dtmf dnis
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 10.0.6.2 255.255.255.192
duplex full
speed 100
ip route 0.0.0.0 0.0.0.0 10.0.6.62
line 0/386 0/409
login authentication noaut
modem InOut
autocommand show ip interface brief
no exec
transport input all
transport output all
escape-character BREAK
It worked. Thank you; much appreciated!
Remember to configure the modems for fast connect, capping max speed to match POS, and use /stream in telnet command.
Thank you for the nice rating and good luck.
