Dial connects then quickly disconnects (less than 30s)
Hi..All
We have a 2610XM Router with NM-16AM-V2.
We use IBM R32 Notebook with built-in Agere System AC'97 Modem to dial and it is no problem.
We use PC with Lemel PCI 56K modem card (ESS ES56H-PI ES2838S chip) to dial and it connects then quickly disconnects (less than 30s).
Cisco 2610XM IOS is c2600-ipbasek9-mz.124-11.T.bin
Our IBM Notebook and PCs' OS are Windows 2000 with SP4.
2610XM config
TW-TPE-C2610XM#sh run
Building configuration...
Current configuration : 1523 bytes
! Last configuration change at 10:47:22 CST Mon Jan 30 2006
! NVRAM config last updated at 10:47:23 CST Mon Jan 30 2006
version 12.4
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname TW-TPE-C2610XM
boot-start-marker
boot-end-marker
logging buffered 32768
enable secret 5 xxxxxxxx
aaa new-model
aaa authentication login default enable
aaa authentication login telnet line
aaa authentication ppp default local
aaa session-id common
clock timezone CST 8
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip name-server 10.32.2.19
ip name-server 10.32.2.21
username test password 7 xxxxxxxx
interface FastEthernet0/0
ip address 10.88.6.18 255.255.255.0
duplex auto
speed auto
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
async mode interactive
peer default ip address pool dialin
no fair-queue
group-range 33 48
ip local pool dialin 10.88.6.80 10.88.6.95
ip route 0.0.0.0 0.0.0.0 10.88.6.1
no ip http server
no ip http secure-server
control-plane
line con 0
line 33 48
modem Dialin
transport input all
autoselect during-login
autoselect ppp
flowcontrol hardware
line aux 0
line vty 0 4
password 7 xxxxxxxx
login authentication telnet
end
TW-TPE-C2610XM#show modem version
Slot 1:
Modem F/W Version : ACF3_V1.824L-V90_4M_RAM
Modem Datapump Version : RCV56DPF-PLL L8773A Rev 62.01/62.01
TW-TPE-C2610XM#sh diag
Slot 1:
Analog Modem Port adapter, 16 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-23028-01
Board Revision : C0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : FOC08041GTR
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Fab Part Number : 28-6305-03
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Field Diagnostics Data : 00 00 00 00 00 00 00 00
Product (FRU) Number : NM-16AM-V2=
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 02 41 01 00 C0 46 03 20 00 59 F4 01
0x10: 42 43 30 80 00 00 00 00 02 03 C1 8B 46 4F 43 30
0x20: 38 30 34 31 47 54 52 03 00 81 00 00 00 00 04 00
0x30: 85 1C 18 A1 03 C4 08 00 00 00 00 00 00 00 00 C5
0x40: 08 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Thanks for any suggestion.
1 REPLY
Re: Dial connects then quickly disconnects (less than 30s)
if the problem is only in the pc, than u have to check for modem and line condition. it can also be a virus problem
Swapnil Jain
135
