br
dial-in: data is lost when doing a tcp-forward aka "TCP clear"
Dear all,
we are using a 3640 for analog dialin. In the router a 2-channel PRI card and two 30-channel digital modems are installed.
When dialling in a TCP connection shall be established to a host (depending on DNIS) and the data be exchanged.
Sounds simple but I have a heavy problem where I don't know what to do:
1st case - Device dials in and sends data first:
- Debug output of router shows the call
- Session is opened, TCP connection is established
- On the TCP host the correctly established tcp connection is visible
*** Obligatory wait of 7 seconds of the device prior of sending data ***
- Data is displayed as hexdump on the host
If I omit the 7 seconds waiting the data send by the calling device is lost anywhere in the router.
2nd case - Device dials in and tcp host sends data first:
- Data is sent to the calling device correctly
- Data exchange works correctly
In this case everything works as it should.
The only difference is that the tcp host is the first one sending data.
FYI: The connect speed is maximum 9600bits/sec.
I read already every doc and newsgroup message but unfortunately no solution for my problem. Please help - any hints or example configs appreciated.
Don't hesitate to ask me more questions or more debug output.
Best regards,
Bernhard Roth
IOS (tm) 3600 Software (C3640-IS-M), Version 12.3(16a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 09-Nov-05 21:49 by evmiller
Image text-base: 0x60008B00, data-base: 0x61BFA000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3640-IS-M), Version 12.3(16a), RELEASE SOFTWARE (fc2)
router uptime is 15 minutes
System restarted at 19:32:41 MEZ Mon Jan 23 2006
System image file is "flash:c3640-is-mz.123-16a.bin"
cisco 3640 (R4700) processor (revision 0x00) with 120832K/10240K bytes of memory.
Processor board ID 26877946
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
MICA-6DM Firmware: CP ver 2950 - 9/9/2003, SP ver 2950 - 9/9/2003.
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
60 Serial network interface(s)
60 terminal line(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Read/Write)
Relevant config-part:
username xxxx nopassword xxxx
username xxxx autocommand telnet 10.xx.xx.xx /quiet /stream
line 1 30
session-timeout 1
no motd-banner
no exec-banner
no vacant-message
modem Dialin
no activation-character
exec-character-bits 8
special-character-bits 8
escape-character NONE
autohangup
dispatch-timeout 250
  • Remote Access
VIP Purple
Re: dial-in: data is lost when doing a tcp-forward aka "TCP clea
Hello Bernhard,
there are numerous bugs in your IOS release...
Can you post the output of ´debug modem´ ? That might render a clue of what is going on...
GP
br
Dear GP,
what IOS-Version is recommended for my application? Below 12.3-12 is not usable because the IOS sorts the config in a wrong way that "username dnis" is not accepted ("aaa new-model" is sorted after user definitions).
As attachment the debug output ("debug modem" and "debug ip tcp transaction") of case 1 (device sends first -> error) and case 2 (server sends first -> works).
Best regards,
Bernhard Roth
br
Hello!
I found the reason why it does not work:
When a modem connects with
CONNECT at 2400/2400 (Tx/Rx), V22bis, Async, None
the router does have problems forwarding the data (data loss)
CONNECT at 2400/2400 (Tx/Rx), V22bis, MNP, MNP5
everything works fine.
We are using currently IOS 12.3-16a
I guess this is related to a bug in the IOS.
Please check
Best regards,
Bernhard Roth
122
