Webcast-Catalyst9k
dial on cisco 1841
i have cisco 1841 with this configuration below.
i add another interface 1-port ADSLoPTS HWIC. and i want to user 2 dial for connexion and specifie the http on one dial with IP static 41.249.250.10 and smtp on the seconde dial with the new IP Static.
Current configuration : 4016 bytes
version 12.4
hostname routeur1841
boot-start-marker
boot system flash:c1841-broadband-mz.124-15.T.bin
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
enable password ****
no aaa new-model
ip cef
ip domain name yourdomain.com
username ***** privilege 15 secret xxx
archive
log config
hidekeys
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
pvc 8/35
interface Dialer0
mtu 1492
ip address negotiated
ip directed-broadcast
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ********
ppp chap password 0 *********
ppp pap sent-username ********* password 0 *********
ip route 0.0.0.0 0.0.0.0 Dialer0 10
ip route 192.168.2.0 255.255.255.0 192.168.1.2
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static esp 192.168.1.2 interface Dialer0
ip nat inside source static tcp 192.168.2.2 110 interface Dialer0 110
ip nat inside source static tcp 192.168.2.2 25 interface Dialer0 25
ip nat inside source static tcp 192.168.1.10 80 interface Dialer0 80
ip nat inside source static udp 192.168.1.2 500 41.249.250.101 500 extendable
ip nat inside source static tcp 192.168.1.2 1721 41.249.250.101 1721 extendable
ip nat inside source static udp 192.168.1.2 1721 41.249.250.101 1721 extendable
ip nat inside source static tcp 192.168.1.2 1723 41.249.250.101 1723 extendable
ip nat inside source static udp 192.168.1.2 1723 41.249.250.101 1723 extendable
ip nat inside source static tcp 192.168.1.2 4500 41.249.250.101 4500 extendable
ip nat inside source static udp 192.168.1.2 4500 41.249.250.101 4500 extendable
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 23 permit 0.0.0.0 255.255.255.0
access-list 23 permit 192.0.0.0 0.255.255.255
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password ******
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
password *******
login local
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
routeur1841#
thanks
1 REPLY
Silver
Re: dial on cisco 1841
Yes this configuration will work. Configure on caller router routing protocols as uninteresting in the interesting traffic definition to prevent periodic hellos from resetting the idle timeout. Since the router uses the interesting traffic definition ONLY to check whether the primary link is active, consider making all IP traffic uninteresting using the command dialer-list number protocol ip deny. With this interesting traffic definition, the idle timeout is never reset, and the router checks the status of the primary link at the specified interval. On the calling router, you do not need to define dynamic routing protocol as uninteresting traffic, as long as the router will not do any dial-out
334
