dial-up disconnect
kpanduric
I have two configurations:
1 - AS5400 receiving dial-up calls (ISDN PRI), building L2TP tunnel to 2800 or 7200 router;
2 - AS5400 also receiving dial-up calls but without L2TP tunnel
Based on username some connections need to be disconnected after some time (configured using Session-Timeout Radius parameter). The second option disconnects clearly, but the first one leaves physical line up on the user side, although access server reports line is down. Is this a known bug? Is there some workaround?
K.P.
a-vazquez
Level 6
Level 6
Since the access server shows that the port is down, there is no call that is active. What is the version of IOS runnning on the remote end routers that are making the call to the access server. You can try doing an upgrade to the latest version and check the status of the physical line when the call is disconnected.
