dial-up to router AUX port need help
Hi guys/gals,
Im setting up a dial-up to router aux port
I just bought a DLINK-562E External Modem with Serial Output, I tried to connect to the DB9 cisco console cable but cant seem to make it work,
I got the config for my aux,
line aux 0
modem DialIn
modem autodiscovery
flowcontrol hardware
speed 9600
stopbits 1
For the DLINK, it uses a Conexant S56D chipset, I used the normal AT commands set by cisco website like AT&S0=2 etc.
Is there a cable difference for this? The link interface is an RS232C interface.
Appreciate your help
1 REPLY
Silver
Re: dial-up to router AUX port need help
Please check below link for the info. :
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
Please follwe the sample and test again by telnet the AUX w/ 2000+line no.
e.g. if "show line" show the line no. is 65. then telnet the port at the router w/ "telnet x.x.x.x 2065".
However, you have to use a PC to connect to the modem to confirm it works then connect to the rouer. You have to use the connector that marked w/ "MODEM" to connect to the modem instead of using the "CONSOLE" connector.
Hope this helps.
146
