dialer replacement technology
I have remote access solution and I am using dialers. As I understand there is limit of number of dilaer interfaces and I am getting close to that limit. What steps should I take? Replace it with waht tecnology? Or can I overcome this limit somehow?
thanks!
1 REPLY
Re: dialer replacement technology
If you are going to exceed the limit then plan for upgradation accordingly or else place NAS/RAS in place of having all the dialers configured in your router.
NAS will take care of if you are using dial in from remote locations.
You can terminate PRI circuits directly onto the NAS and have your authentication pointing towards your AAA servers..
regds
113
