Community Member
dialup connection sporatically dials
I have two sites linked together via microwave with dialup as backup solution.  I have an IP SLA monitoring the main link and activates the dialup when the link goes down.
Well, my problem is that the SLA errorously sees the main link go down and kicks in the dialup.  BUT just for a few seconds and once it sees the main link up it, of course, drops the dialup.
On both ends, I have increase the timeout from 1000 to 10000 and changed the frequency to 51.  Hoping that prohibit the dialup.  But it hasn’t.
I have added the SLA config for your reference.
This is the far-end RTR
ip sla monitor 11
type echo protocol ipIcmpEcho 10.30.12.2
timeout 10000
threshold 4
frequency 51
ip sla monitor schedule 11 life forever start-time now
this is the central RTR
ip sla monitor 12
type echo protocol ipIcmpEcho 10.30.51.254
timeout 10000
threshold 4
frequency 51
ip sla monitor schedule 12 life forever start-time now
I think I need to change the SLA statement but I’m not sure.
Thanks, Gary
Re: dialup connection sporatically dials
Hi Gary
Can you tell me what is the ip which you are monitoring using sla? (10.30.12.2 / 10.30.251.54).
Also can you post the output of show run/show log/show ip route here
regds
Community Member
the far end is monitoring 10.30.12.2 and the central RTR is looking at 10.30.51.254
Goodland is the remote RTR
217
