disable load balancing on dual PRIs - 3640 with MICA modems for dial out
shahidsheikh
We have a custom application that connects through reverse telnet to a Cisco 3640 that has 2 NM-24DM modules and 2 PRIs connected to it. Currently all outgoing calls are getting load balanced over the two PRIs. I need to change that so that all calls go over the first PRI and when all channels are used up, it starts using the second PRI. Seems like a simple enough thing to do but I can't figure out how to.
Here is my config
Current configuration : 1401 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname DIALOUT01
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxx
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
no ip routing
no ip cef
no ip domain lookup
ip domain name xxxxxxx.xxx
isdn switch-type primary-ni
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description xxxx
controller T1 0/1
framing esf
linecode b8zs
description xxxx
interface FastEthernet0/0
ip address dhcp hostname dialout01
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
interface Serial0/0:23
no ip address
encapsulation hdlc
no fair-queue
no cdp enable
interface Serial0/1:23
no ip address
encapsulation hdlc
no fair-queue
no cdp enable
no ip http server
control-plane
line con 0
line 33 56
modem InOut
modem autoconfigure type mica
transport preferred telnet
transport input telnet
transport output telnet
line 65 88
modem InOut
line aux 0
line vty 0 4
password 7 xxxxx login
end
Shahid
Phillip Remaker
If I understand the question I think that isdn  bchan-number-order is the command you are interested in.  I think it detaults to round-robin, sounds like you want ascending (that is isdn  bchan-number-order ascending).  It is an interface subcommand.
See  http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gt_ibcac.html#wp1055853
That may only apply to native ISDN calls and not MICA based calls, but see if that helps.
