Disconnect ISDN connection
I was wondering if it is possible to force an ISDN disconnect after a specific amount of seconds. Not just the dialer idle-timeout => If interesting traffic is going over the line, this timer will be reset constantly.
I would like to know if there is another mechanism to force a disconnection after five minutes..
Remco
1 REPLY
Silver
Re: Disconnect ISDN connection
think the only way to force ISDN disconnect is using "dialer idle-timeout" command.
Refer the following url for more info on dialer idle-timeout usage and configuration:
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t1/feature/guide/dtidle.html
282
