Dnis pattern inside a vpdn-group
cxantzis
Hello all,
i have a dnis-based dial-in vpdn configuration on my LAC and need to add 10 consecutive dnis numbers to this group.
Any way to make a single wildcard entry to do it, instead of 10 separate entries? All my attempts to use a dial-peer like pattern failed and only with a specific dnis full match the session was indeed identified and forwarded to LNS.
The config is something like this:
vpdn-group test
request-dialin
protocol l2tp
dnis <>
dnis <>
initiate-to ip X.X.X.X.
etc
Thanks in advance.
Chris.
didyap
Level 6
Level 6
To configure a tunnel switch (or multihop node) that supports the VPDN Multihop by DNIS feature, you need to configure a tunnel switch that contains both the LNS and LAC portions of the VPDN. Use the following commands:
1. enable
2. configure {terminal | memory | network}
3. username {local-name | remote-hostname} password secret
4. vpdn enable
5. vpdn multihop
6. vpdn-group name
7. vpdn-group subcommands (accept-dialin and terminate-from for the incoming portion of the tunnel switch, and request-dialin and initiate-to for the outgoing portion, for example)
8. vpdn search-order {dnis | multihop-hostname | domain} (optional step that should be executed only when it is necessary to change the default search order)
