Webcast-Catalyst9k
DSL: Remote to inside (Gotta be ez)
Small Business, no IT but me.
We have a Cisco 1812 behind an AT&T Netopia 3346N DSL Switch. We are trying to provide outside PCAnywhere access to a PC on the inside. I opened (suggested by the folks at Netopia) a pinhole on the Netopia switch for PCAnywhere, but still cannot get to the 1812 > server > PC.
Right now, we only require one (1) remote user for a short period of time. (I've hired a young IT whiz who will configure the appropriate VPN for our long-term remote requirements, but the start date is next week.) I need to allow our ERP supplier access to our system for an upgrade before Oct 1st. We planned on performing those activities this weekend.
Thanks for any help!
!This is the running config of the router: 192.168.168.200
!version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname STCLAIR1
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret xxx
no aaa new-model
resource policy
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.168.200
ip dhcp pool sdm-pool1
import all
network 192.168.168.0 255.255.255.0
default-router 192.168.168.200
ip dhcp pool sdm-pool2
import all
network 10.0.0.0 255.255.255.0
ip tcp synwait-time 10
no ip bootp server
ip domain name stclairpackaging.com
ip name-server 6X.9X.1XX.1XX
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-111111111
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-111111111
revocation-check none
rsakeypair TP-self-signed-111111111
crypto pki certificate chain TP-self-signed-111111111
certificate self-signed 01
3082024...1A1E06
quit
username admin privilege 15 secret 5 $1$....
interface FastEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
duplex auto
speed auto
interface FastEthernet1
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address dhcp client-id FastEthernet1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 192.168.168.200 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
interface Vlan2
ip address 10.0.0.250 255.255.255.0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet1 overload
ip nat inside source static tcp 10.0.0.250 80 interface FastEthernet1 80
ip access-list extended PCAnywhere
remark SDM_ACL Category=1
remark Advanced Software
permit ip host 67.62.XXX.YYY host 10.0.0.111
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.168.0 !
end
(I had to cut some of the length due to the restriction)
Re: DSL: Remote to inside (Gotta be ez)
interface Vlan2
ip nat inside
Plus you have the same IP address on vlan2 interface and your actual server.
interface Vlan2
Thanks, but I am not clear on what exactly to do with these values. Do I remove vlan2 and rebuild it with merely the ip nat inside line?
I use the SDM rather than CLI (since it warns me prior to entering that mode that "Expert User" skills are necessary) and I still struggle with just what parameters are set by what fields in SDM. I've got the 1812 offline right now and am considering a restart.
We've got several PCs running static IPs (legacy setup) and several running on DHCP. I'm thinking I should move all to DHCP? Then I only require vlan1, right?
234
