dynamic or static IP required
I have a 871-K9 router and want to set up a 2003 server behind this. Cable modem IP is dynamic and tracked by Dynip service - can the 871 be configured to assign static IP to the server with access through the cable modem and router?
Silver
Re: dynamic or static IP required
Yes, Its possible to configure the 871 to assign static ip to the server . For more onformation regarding the configuration, Please follow the url given below,
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/prod_bulletin09186a00801abfda.html
the ip address with dhcp will probably not change since the router will typically assign it the same ip address to it's MAC address.
put this in your config
#ip dhcp excluded-address 192.168.xx.xx
where the number is your server, then just go into the server and put in that static address
128
