E1 Problem_E1 state change alternatively
I have a 7204VXR BRAS with several E1 IMA,
but state one of them change alteratively , I use same config for all of them .
I use this E1 for transfer date to my DSLAM .
here is its config :
vpdn enable
bridge irb
interface FastEthernet0/0
ip address 192.168.*.* 255.255.*.*
duplex full
speed 100
pppoe enable
interface ATM1/2
no ip address
carrier-delay 60
scrambling cell-payload
framing crc4adm
ima-group 2
interface ATM1/ima2
description ******** *, * ********
ip address 10.0.*.* 255.255.*.* carrier-delay 60
no atm ilmi-keepalive
range 1 pvc 0/32 0/200
encapsulation aal5snap
protocol pppoe
pvc 1/32
protocol ip 10.*.*.* broadcast
I changed my dslam , the path of E1 from DSLAM to BRAS but my problem is still alive !
and E1 log is here :
Jul 8 12:12:18: %LINK-3-UPDOWN: Interface ATM1/2, changed state to up
Jul 8 12:23:03: %SYS-5-CONFIG_I: Configured from console by amir on vty0 (85.13
3.131.8)
Jul 8 12:27:39: %IF-4-BACKWARD_COUNTERS: Corrected for backward rxtx_errors cou
nters (172410 -> 172305) on ATM1/ima2
Jul 8 12:28:36: %LINK-3-UPDOWN: Interface ATM1/2, changed state to up
Jul 8 12:31:40: %LINK-3-UPDOWN: Interface BVI2, changed state to down
Jul 8 12:31:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI2, changed s
tate to down
Jul 8 12:31:50: %LINK-3-UPDOWN: Interface BVI2, changed state to up
Jul 8 12:31:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI2, changed s
tate to up
Jul 8 12:32:39: %LINK-3-UPDOWN: Interface ATM1/2, changed state to up
Jul 8 12:38:49: %LINK-3-UPDOWN: Interface ATM1/2, changed state to up
Jul 8 13:09:23: %LINK-3-UPDOWN: Interface ATM1/2, changed state to up
Re: E1 Problem_E1 state change alternatively
I would check with your provider first, to see if the errors are coming from that side...
GNT
first I'm sorry for my bad english.
This E1 is a P2P E1 for transfer my date to adsl user from my centeral office where my BW is exit to telecommunication PCM branch where user phone line are terminated.
My E1 cross on Coaxial from DSLAM to PCM and cross Optical fiber from PCM to MY centeral Office.
This E1 is n't a PRI or CAS.
My BRAS is a 7204VXR with 256M SDRAM and My IOS is
c7200-js-mz.124-3.bin nad My DSLAM is Siemens hix5300 .
1-I perform a loopback check with my provider,
when I created a loopback, there was no UpDown errors and when i delete loopback for 7 or 8 hour there was no error but after that errors appear again.
2-I changed Coaxial cable and one time changed E1 path on Optical fiber but problem still remain.
Do you think a synchronization problem is source of problem ?
I draw the path in this file.
135
