EAP in ayncronos interface (Authetitication with certificates)
We want to know if it is posible to login for asyncronous interfaces with certificates
1 REPLY
Re: EAP in ayncronos interface (Authetitication with certificate
It depends on what you are doing on the async interface. If there is a "dumb" terminal connected to it you will not be succesfull. The end host must have enough intelligence to handle the certificate. It will be possible if you are running ip over the link. (example: SLIP or ISP dial-up)
However: Authenticating and negotiating the certificate involves quite some traffic and hence I would not recommend using this option while many async lines will simply not offer sufficient reliability and bandwidth.
Leo
118
