Error problem on 1841 cisco router
00:29:16: ASSERTION FAILED: file "../chips/gt96k/gt96k_timer.c", line 771
The above error console message is coming on cisco 1841 router.
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.3(8)T8, RELEASE
OFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 06-Apr-05 02:17 by yiyan
Following is the output of show version.
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
uptime is 31 minutes
System returned to ROM by reload at 09:05:05 UTC Fri Oct 7 2005
System image file is "flash:c1841-ipbase-mz.123-8.T8.bin"
Kindly suggest and recommend
Sanjay Kapoor
skapoor@hughes-ecomm.com
Hall of Fame Super Silver
Re: Error problem on 1841 cisco router
Sanjay
I believe that ASSERTION FAILED errors indicate a severely unexpected action or condition in the software. I believe that the appropriate thing to do is to open a case with the TAC on this.
Rick
Can ios upgrade can resolve this problem or what ios version.
Sanjay Kapoor
Sanjay
I still believe that the best thing to do is to open a case with TAC about this problem. But if you do not want to open a case for some reason then upgrading the IOS would be a reasonable thing to do and would probably resolve the problem. I have been running 12.3(11)T8 on 1841s with reasonably good success.
Rick
204
