EZVPN, not able to ping anything on LAN
                  Hi all,
I have been trying to set up a remote access split tunnel VPN.  I have managed to get the VPN up and working apart from I can not access or ping any internal devices from the client once connected to the VPN.
I believe the issue probably lies with NAT and or access-lists and have got a little bit stumped now   I have attached my config so if anyone could help I would much appreciate it
Thanks all,
Shaun
1 REPLY
Re: EZVPN, not able to ping anything on LAN
I have managed to sort it... I have removed the dynamic mapping and created an ipsec profile and virtual template.
I have attached the working config in case it helps anyone else
Shaun
293
