EzVPN w/ 2811 & CCP, clients received 0 packets
a3948692
Hi all,
I've tried to create a EzVPN server on my 2811 router, I've try many options and try to clear firewall settings.
Clients can connect, with CISCO VPN Client 5.007.0290, but they allways not receiving 0 packets.
CCP version is 2.3, and IOS is 2800 advanced ip service, 150-1.M4. , also i've try 124-15.T12
any comment is appreciated
update: I've recreated a vpn from a "fresh" config. removed "dpd" now iphone client can login but like pc clients, 0 packets received.
enclosed is the new config and the "sh crypt ipsec sa" result.
lgijssel
Level 9
Level 9
First of all, you do not need the secondary ip addresses on your public interface:
ip address x.x.x.85 255.255.255.240 secondary
ip address x.x.x.86 255.255.255.240 secondary
ip address x.x.x.87 255.255.255.240 secondary
ip address x.x.x.88 255.255.255.240 secondary
Also, take note that EzVPN encapsulates ESP in UDP (to allow nat).
Therefore, acl's matching esp are possibly not correct.
regards,
Leo
thanks, i've just post update config/results above.
