FQDN for SSL VPN
proneker1
Dear Experts,
I have alrady configured SSL VPN on ASA 5510 (8.2-1) and working properly. But please let me know it is possible to modify or change the fqdn name in ca configuration portion.Or I have generate new key with new fqdn name. Highly appreciated if you guide me or give me reference article link. Thank you.
Is the ASA the CA server?
Sent from Cisco Technical Support Android App
Yes, self-signed cert - CA. Sorry for late reply.
Hi Thet,
You can change the FQDN and generate the SSL certificate without creating a new RSA keypair.
Of course, you will need to have your clients install this new certificate onto their systems.
Please let me know.
Thanks.
Portu
Please rate any posts that you consider helpful.
