FRAME RELAY HUB AND SPOKE ROUTERS
jabbar154
IN FRAME RELAY HUB AND SPOKE TOPOLOGY
THERE IS STATIC MAP ENTRIES
I HAVE TWO QUESTIONS
1. IF SPOKE ROUTER DO NOT PING EACH OTHER WHAT IS SOLUTION OR EXTRA COFIGURATION REQUIRED
2. IS ONE DLCI FROM A ROUTER MAP WITH TWO REMOTE ADDRESSES.
devang_etcom
Level 7
Level 7
yes you can have it...
lets say router A is hub router and having two spoke router B and router C...
now you can have DLCI like
router A use DLCI 101 to reach B
router A use DLCI 102 to reach C
Router B can use DLCI 201 to reach A and C
Router C can use DLCI 301 to reach A and B
by this way you can have partial mesh configuration and you can have configuration like this...
DLCI 202 to reach C
DLCI 302 to reach B
hope this will clear your idea
rate this post if it helps
regards
Devang
