Webcast-Catalyst9k
Help~ Why my EZvpn connection alway broken after around 110 seconds
Hi, I use Cisco VPN Client Software Release 4.7.00.0053, connect to a Router which acts as a EZVPN Server, but after each connection, it always broken after 100 to 110 seconds. the Router is C2811 with IOS 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(10), RELEASE SOFTWARE (fc1).
The VPN soft report that the reason 412: The remote peer no longer responds.
and I can't build a banner in the:
crypto isakmp client configuration group Group1
it doesn't know the command "banner"
1 REPLY
Silver
Re: Help~ Why my EZvpn connection alway broken after around 110
Make sure the ESP protocol, UDP 500 and UDP 4500 are not blocked.First use crypto isakmp client configuration group {group-name} and then use banner c.Refer the following URL for more information
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b6a.html#wp1153004
139
