Help with VPN on 1841 please
Would very much appreciate some assistance configuring client/server VPN on 1841 Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(25g)
CISCO_1841#sho run
Building configuration...
Current configuration : 6155 bytes
! Last configuration change at 20:56:15 EDT Tue May 20 2014 by northnet
! NVRAM config last updated at 20:46:06 EDT Tue May 20 2014 by northnet
version 12.4
service timestamps log datetime msec localtime
service password-encryption
hostname CISCO_1841
boot-start-marker
boot config flash:running-config
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1$NQDK$tuRCWqVxH7tRsZdHSczUJ1
aaa new-model
aaa authentication login default local
aaa authentication login userauthen local
aaa authorization network default local
aaa authorization network groupauthor local
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1 192.168.100.25
ip dhcp pool DATA
   network 192.168.100.0 255.255.255.0
   dns-server 75.75.75.75 8.8.8.8
   default-router 192.168.100.1
ip dhcp pool WIRELESS
   network 192.168.103.0 255.255.255.0
   default-router 192.168.103.1
ip dhcp pool CANON
   host 192.168.100.5 255.255.255.0
   client-identifier 0100.1e8f.39c0.c4
ip dhcp pool NETGEAR_AP
   hardware-address 0018.4d49.7796
ip dhcp pool MONITOR
   host 192.168.100.174 255.255.255.0
   client-identifier 0100.2170.476e.10
ip dhcp pool VOIP
   network 192.168.102.0 255.255.255.0
   default-router 192.168.102.1
ip dhcp pool SUT
   network 192.168.101.0 255.255.255.0
   default-router 192.168.101.1
ip ddns update method no-ip
 HTTP
  add http://xxx:xxx@dynupdate.no-ip.com/nic/update?hostname=x.x.x&myip=x.x.x.x
 interval maximum 0 4 0 0
async-bootp dns-server 8.8.8.8
crypto pki trustpoint TP-self-signed-2714623577
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2714623577
 revocation-check none
 rsakeypair TP-self-signed-2714623577
crypto pki certificate chain TP-self-signed-2714623577
 certificate self-signed 01
  30820257 308201C0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32373134 36323335 3737301E 170D3134 30353138 32333530
  34345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37313436
  quit
username xxx secret 5 $1$ffKd$1jNa1UZmYz8x/wmHWowlh.
username xxx secret 5 $1$ePv7$ohkQUL0maM1RbPOMF/Sxg/
username xxx secret 5 $1$9Qku$fWUZUC68QFEp43q2fMwd31
username xxx privilege 15 password 7 0305550F140A36181B504E
username xxx privilege 15 secret 5 $1$eXR.$oGpc7tWWGlf0LwDX6NMag0
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp client configuration group vpnclient
 key northnetvpn
 dns 8.8.8.8
 pool DATA
 acl ACL_MATCH_LOCAL
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
 set transform-set myset
 reverse-route
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
 ip ddns update hostname northshire.no-ip.biz
 ip ddns update no-ip
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
 no cdp enable
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/1.100
 encapsulation dot1Q 100
 ip address 192.168.100.1 255.255.255.0
 ip nat inside
interface FastEthernet0/1.101
 encapsulation dot1Q 101
 ip address 192.168.101.1 255.255.255.0
 ip nat inside
interface FastEthernet0/1.102
 encapsulation dot1Q 102
 ip address 192.168.102.1 255.255.255.0
 ip nat inside
interface FastEthernet0/1.103
 encapsulation dot1Q 103
 ip nat inside
interface Serial0/0/0
 no ip address
 shutdown
no ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list ACL_MATCH_LOCAL interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.100.174 3389 interface FastEthernet0/0 3389
ip dns server
ip access-list extended ACL_MATCH_LOCAL
 permit ip 192.168.0.0 0.0.255.255 any
 permit ip 192.168.100.0 0.0.0.255 any
 permit ip 192.168.102.0 0.0.0.255 any
 permit ip 192.168.103.0 0.0.0.255 any
 permit ip 192.168.101.0 0.0.0.255 any
control-plane
line con 0
line aux 0
 transport input ssh
line vty 0 4
 privilege level 15
 transport input telnet ssh
 transport output telnet ssh
line vty 5 15
 privilege level 15
scheduler allocate 20000 1000
ntp clock-period 17178996
ntp server 198.144.194.12 prefer
end
1 REPLY
Anyone have any suggestions
Anyone have any suggestions for me?
60
