ian
How do I set a 804 ISDN router to connect on startup?
I am using a Cisco 804 ISDN router. Unfortunately due to area constraints this is what we have to use. I need this to dial out at router startup. I have dug through config option, this forum, and over Internet and can't find a solution anywhere. I have it set for no idle timeout and have tried multiple threshold settings to try to get this to work.
Re: How do I set a 804 ISDN router to connect on startup?
can you post your config here and also the exact requirement you have in place out there ?
regds
ian
This is a Cisco 804 ISDN router being used for a internet and remote access for the customer. It needs to be able to be up 24/7. As such it needs to automatically connect and if possible reconnect if the connection is dropped. I have searched everywhere on this and can't seem to find what I am looking for.
===========Current Config==============
no service udp-small-servers
no service tcp-small-servers
service password-encryption
hostname
username password
enable secret
no ip source-route
isdn switch-type basic-ni
ip routing
ip classless
ip subnet-zero
pots country US
dial-peer voice 1 pots
destination-pattern 3430315
port 1
dial-peer voice 2 pots
destination-pattern 3431591
port 2
interface ethernet 0
keepalive
no shutdown
ip address 66.x.x.x.255.255.252
ip route-cache
no ip proxy-arp
no ip directed-broadcast
ip access-group 121 in
interface bri 0
encapsulation ppp
ppp authentication chap pap callin
ppp multilink
isdn spid1 54134303151111 3430315
isdn spid2 54134315911111 3431591
dialer pool-member 1
isdn incoming-voice modem
no shutdown
interface dialer 1
dialer remote-name Cisco1
dialer pool 1
no ip split-horizon
description ISP
encapsulation ppp
dialer idle-timeout 300
dialer hold-queue 10
dialer-group 1
dialer string 7621234 class DialClass
ppp authentication pap callin
ppp pap sent-username xxx password xxx
ppp multilink
ip address negotiated
ip route-cache
no ip proxy-arp
map-class dialer DialClass
dialer isdn speed 56
dialer-list 1 protocol ip permit
no router rip
ip route 0.0.0.0 0.0.0.0 dialer 1
access-list 18 permit 66.178.130.44 0.0.0.3
access-list 121 deny udp any eq 138 any
access-list 121 deny udp any eq 137 any
access-list 121 deny udp any eq 139 any
access-list 121 deny tcp any eq 137 any
access-list 121 deny tcp any eq 138 any
access-list 121 deny tcp any eq 139 any
access-list 121 permit ip any any time-range TIME
time-range TIME
periodic daily 00:00 to 23:59
line console 0
exec-timeout 120
line vty 0 4
exec-timeout 0
login local
end
To bring up & nail up the isdn connection use any of the below options
1) Use Dialer persistent as explained by the below link
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080454ff8.html
Note this nails the conection up even with no traffic
2) Configure NTP or a routing protocol to generate interesting traffic
PS.
- You currently have an idle-timeout of 300sec use the max value or 0 to nail it up
- threshold settings is used to bring up an additional B channel
ian
Thanks for the response. dialer persistant didn't work because I was only using IOS 12.1. I was however able to get SNTP to set traffic out to bring up the connection. Thank you for the assistance.
141
