How to connect Internal Network using VPN?
I have 2 Local Area Networks routing thru 1 CISCO 2811, then 2811 connected to linksys RVS-4000. How to configure these both to access internal Lan Network(s) of 2811 via VPN Internet. Diagram Attached. Please suggest.
1 REPLY
Re: How to connect Internal Network using VPN?
Rahul,
I see you have 2 options:-
1) Create and terminate a VPN to the Linksys
2) Create and terminate a VPN to the 2811 router.
Both of the above options will allow you to access the internal IP subnets from the internet using a VPN client and or site2site VPN.
HTH>
146
