how to set pppoa adsl with fix ip address on cisco 877?
weerapatr
I purchase a cisco 877 router and package adsl with fix ip address how to config it.
I found a way config with interface dialer with negotiate ip addresss which I think this is adsl with dynamic ip address.
Config ip address on interface atm0/0?
Config ip address on interface dialer?
Please advice and ref.
Thank in advance
desai.jaideep
Level 5
Level 5
That ip address has to be mentioned in Dialer interface not atm interface.
PPPoA architecture can be found at :
http://www.cisco.com/warp/public/794/pppoa_arch.html
And the configuration guide can be found at:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hbba_c/index.htm
JD
ivanmoreira1130
Hi, try this
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address ?ip and subnet?
ip mtu 1492
ip nat outside
no ip virtual-reassembly
ip tcp adjust-mss 1452
pvc 0/37
encapsulation aal5snap
paolo bevilacqua
Please ask ISP if they are using "bridged RFC 1482 or RFC 2684". If yes, then configure:
bridge irb
interface atm0.1 point-to-point
pvc
bridge-group 1
interface bvi1
ip nat outside
ip address
bridge 1 protocol ieee
bridge 1 route ip
