Hub and Spoke IPSEC VPN
ravisambaji
I have Cisco 7206VXR VPN concentrator at DC and Cisco 1841 router at my 100 remote offices. I want to establish Hub and spoke ipsec vpn, where my remote office ipsec tunnels will terminate to VPN Concentrator at DC.
I need advise on
1) should i go with static ipsec tunnel configuration at VPN concentrator for each remote office or
2) should i configure the dynamic ipsec tunnels at VPN concentrator to all my remote offices, If i have to configure the dynamic ipsec tunnels at VPN Concentrator, can you share the configuration sample
Help is appreciated.
Ravi
paolo bevilacqua
search CCO for "dmvp white paper". All the configurations are in there. recommend you get and HW VPn accelerator also.
HI,
Thanks, i did search for DMVPN but iam finding the info like MGRE over IPSEC, but i just want hub and spoke IPSEC configuration for ios based platform, which iam not finding it.
Ravi
