IOS without remote access
I would like to use remote vpn anyconnect but my IOS routers do not support , can someone please help taking ?
VIP Purple
If your router doesn't support AnyConnect you need a different router or more likely a different IOS-version or license. Which router do you have? If it's an IOS-device pleas paste the output of "show version".
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Re: IOS without remote access
Even if you have the correct software and license you're also going to need some config. Out of the box, a Cisco router is pretty much a blank slate.
I just bought that router 892W for my studies do not know that I have a license?
VIP Purple
That router comes out of the box with the right feature-set and license.
Now you should start learning the basics of Cisco IOS (there are many beginner-books available), and later you can go to the more advanced features like Anyconnect. If you just want Anyconnect you could load the Cisco Configuration Professional and configure your router with a grafical user interface.
yes but would much rather work with command line interface but how can you configure?
VIP Purple
you could start ith a CCNA-Book. That's for Cisco-beginners.
http://www.amazon.com/Routing-Switching-Foundation-Learning-Official/dp/158714378X/ref=sr_1_26?ie=UTF8&qid=1378794461&sr=8-26&keywords=cisco+ios+fundamentals
Hall of Fame Super Gold
Actually, SSL VPN on 890 routers requires an additional license license
FL-SSLVPN25-K9
Feature license SSLVPN for up to 25 users (incremental), for 15.x based Cisco IOS Software releases only
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78-519930.html
One can activate a temporary evaluation license.
VIP Purple
oh yes, I forgot about these ... was just thinking about the general Security-feature-set.
503
