IPsec SAs removed from ASA 5510
My ASA5510 7.2 IOS version, from time to time remove all IPSec an IKE SAs. Which debug command should I used in order to know what `s happended. I`m sending debug output to a syslog server.
Re: IPsec SAs removed from ASA 5510
you can find the complete list of syslog message numbers here
http://www.cisco.com/en/US/docs/security/asa/asa72/system/message/syslog.html
find the syslog number that will give you what you need and do the following
1) logging on
2) logging list test message
3) logging trap test
4) logging host <> x.x.x.x
Logging is already enable. I had configured ...
#logging class vpn trap Emergencies
... but I don`t see the reason why the appliance is tacking vpn connections down.
Do you have any suggestion of which debug command should I use.
163
